Codes on my 6.0 need help
Old Nov 14, 2012 | 10:51 PM
iam4x4's Avatar
Default Codes on my 6.0 need help
Hey guys, a bunch of of check engine codes came up all at once, and also my rear interior light is staying on? I'm assuming a short somewhere in the system, but If anyone could have an. Idea here are the codes coming up:
P0460 fuel level sensor, a circuit p0463 fuel level sensor high input sensor, P0470 exhaust pressure sensor, p0480 fan1 control. Circuit, p0528 fan speed sensor circuit no signal, p1000 obd systems readiness test not complete
If anyone can help would save me a lot of time
Old Nov 15, 2012 | 09:43 PM
farm boy's Avatar
The P0463 fuel level sensor high input is just a dirty resister card. to clean this resister card the most effective way would be, to drop your fuel tank remove the fuel level sender and you will find a white plastic cover, under that cover is the resister card, carefully remove the white plastic cover and this card will need to be cleaned off with some techron additive fuel cleaner by using a q-tip, reassemble and your good to go, if you want to hold off on the troubles of dropping the tank, you can purchase this techron additive fuel cleaner at your local auto parts store for about 6 to 10$ and fill the tank to full and drop this fuel cleaner in your tank, you might have to do this about 3 times before the resister card is clean enough to read correctly note this does not clean it as effectively but will save you alot of headaches for couple month till the check engine light pops back on and repeat the process. the P0470 just take the exhaust sensor off and clean it and that will get rid of that code.
Old Nov 16, 2012 | 01:46 PM
iam4x4's Avatar
thanks man ill try adding it to the fuel, its like -20 dress celcius here too cold to be on the ground
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
JaysTruck
Jul 22, 2015 11:49 AM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
angies04
Sep 29, 2014 04:11 PM
