Intermittent ecm code? Wtf? Tuner to blame?
Old Nov 14, 2012 | 03:38 PM
CumNasty's Avatar
Default Intermittent ecm code? Wtf? Tuner to blame?
Truck shot an idiot light at me that says intermittent power from ecm...my odometer now only comes up after truck is shut off even if I had it on trip. Oil change light comes on after its reset and I just changed oil. Also mpgs dropped significantly and it idles shakey. Rund good but vibrates at idle. Also have thw lightning bolt with two lines light on dash. Wtf is going on
Old Nov 15, 2012 | 04:37 PM
The black pearl's Avatar
Hey im not sure but it sounds like a loose battery terminal. Loose fuse or a possible ground fault. I got the same thing for oil change. I usually run a code for crankcase filter when hooked up to smarty. The best thing us to check electrical connections as a dealer has no troubleshooting skills. They start replacing things first and see if that works . Start with basics always. Just my .02 cents
Old Nov 15, 2012 | 05:21 PM
nwright002's Avatar
i agree with black pearl.. or it might be possible that your alternator is on the fritz
Old Nov 15, 2012 | 06:05 PM
CumNasty's Avatar
I did notice that my battery connection looked like a science experiment....I cleaned all the connections and checked for anything stupid. When my truck idles it will dim lights and voltage gauge will drop and go back up. It has done this since i bought the truck but i neer worried about it. What gets me is this light with a lightning bolt and two lines...What does it mean? And btw i just updated my tuner about five minutes ago ill see what happens on drive in to work tmw
Old Nov 15, 2012 | 06:54 PM
nwright002's Avatar
im guessing when your light and dash lights go dim your grid heater is kicking on... and your voltage drops between 11 and 12.
Old Nov 16, 2012 | 06:44 AM
CumNasty's Avatar
Didnt think about that very possible.im on my way to work now and after tuner update last night lights are in again
Old Nov 16, 2012 | 08:41 AM
Rail's Avatar
lightning bolt on my dash read out tells me the cargo light is on? that's the button right below my dash dimmer roller switch. If I leave it on, duh, like I did one time for a week the lights' would dim. Doggone new fangled pieces of equipment anyway, I miss my old T, you could shock guys when they lean on your truck with the magneto, them was the good ole days, eh? layin on the side of the road changin the bands out every 100 miles or so, summer or winter, man I just miss those days.
Old Nov 16, 2012 | 09:09 AM
bananawing's Avatar
Rail, how do you shock with a mag? I would love to light up people who go hands on, without permission to touch my '24 Tudoor.
Sorry to go OT, but this is important stuff. At least my Dodge hauls the T on a trailer.
Old Nov 16, 2012 | 10:07 AM
USMC041205's Avatar
I need to check that out also ...I have had that light since I recently bought the truck from the dealer. But, the strange thing is that it goes out shortly after my coil warms up ..or maybe it's not strange ...
Old Nov 16, 2012 | 10:59 AM
Farmboy 2.0's Avatar
Have your batterys and alternator checked.If not i had one truck that had a loose pin on the ecm that did the same thing
