93 chevy 2500 6.5 to 12 valve cummins swap
Old Nov 13, 2012 | 11:10 AM
93chevy6.5's Avatar
Default 93 chevy 2500 6.5 to 12 valve cummins swap
i bought a 93 chevy 2500 single cab 4x4 completly rust free. had a bad motor when i bought it so i pulled it and the transmission i wanna put a 12 valve cummins in it with a nv4500 tranny only problem is my truck is an auto what do i need to do to swap it to a manual ? also i wanna be able to do a little sled pullin with this truck but also keep it streetable how should i go about this ? any and all advice will be greatly appreciated.
thanks,
will
Old Nov 13, 2012 | 11:57 AM
racer55's Avatar
Dodge used the NV4500 also,I expect you would need the adapter plate or the dodge bell housing,a flywheel and clutch plus a clutch peddle-hydraulic from a 96 chev might work well?
Old Nov 13, 2012 | 12:04 PM
93chevy6.5's Avatar
Is there any difference for the chevy nv4500 and the dodge nv4500? I was going to use a chevy nv4500 so I could use my stock transfer case.
Old Nov 13, 2012 | 12:20 PM
racer55's Avatar
As far as I know the output shaft on the dodge nv 4500 uses a different spline than the chev,you would also want to use a chev clutch disc-I am not sure if the dodge and chev input shaft is the same or not?
Old Feb 15, 2013 | 09:44 AM
sr71sss's Avatar
the chevy nv4500 has to be a post 1995 since the case bolt pattern was different, I had a mid year 1995 nv4500 and it was the case that had the wrong bolt pattern
Old Mar 17, 2013 | 06:45 PM
aroy308's Avatar
The 92 93 94 Chevy nv4500 will work as long as you get a Chevy Cummins adapter plate and starter the harder part will be finding the flywheel. You can find the whole setup on grumman vans ie twinkie or bread trucks
Old Aug 6, 2014 | 02:06 PM
Detroit6.5's Avatar
I know this is an older post but I'm doing almost the same swap on my 93 k3500. I'm going to retain the stock gm nv4500 and use this kit seems to be just whats needed to make everything work correctly. TRANSMISSION ADAPTERS
DieselDan370
Aug 23, 2016 02:24 PM
DirtyDiesel58
Jun 7, 2015 11:50 PM
river rat
May 18, 2015 05:04 PM
ReckONE
Feb 25, 2015 09:41 AM
Snoobly
Dec 11, 2014 11:59 AM
