Auto High-Idle
Old Nov 13, 2012 | 01:00 AM
Diesel Addict101's Avatar
Default Auto High-Idle
Alright I was just driving at operating temperature on a county highway at roughly 60 mph for about 10 minutes. When I pulled into the driveway and put my truck in park I usually let it sit a little bit anyways. But no more then 3-4 minutes after letting it sit auto high-idle kicked in for roughly a minute. Is this a glitch in the system? or is this an effort to cool the engine or the turbo? Just wondering. Thank you.
Also does this truck also have 3 cylinder mode as well?
Last edited by Diesel Addict101; Nov 13, 2012 at 01:00 AM. Reason: Automerged Doublepost
Old Nov 13, 2012 | 06:57 AM
steved's Avatar
Auto high idle helps keep the coolant at a certain temperature and to prevent cylinder wash down...if it was above 40*F, you may have another issue causing the truck to think it needs high idle (bad thermostat or temperature sender).
I want to remember the automatic equipped trucks can also be manually put into high idle using the cruise control switches.
I think the 3 cylinder thing is a 2nd gen option...
If it was loping when it went into high idle, start saving $$ for injectors...
Old Nov 13, 2012 | 12:59 PM
TheOtherNick's Avatar
3rd gens have 3 cyl mode also.
Old Nov 13, 2012 | 10:15 PM
steved's Avatar
Not unless someone is making it happen with a programmer...stock they don't.
Old Nov 14, 2012 | 02:25 AM
Well I tell ya what she wasnt loping so thats good. And how can it be put in high-idle manually? Also as far as the coolant temp goes I will say that when I let it sit for like not even 5 minutes it goes from operating temperature to a 1/4 on the temp gauge... bad thermostat could be possible if shes stuck open. It would probably be one of the cheaper replacements.
Old Nov 14, 2012 | 10:44 PM
Dealer can flash ya with manual high idle and 3 cylinder mode.
Old Nov 15, 2012 | 01:10 AM
I suppose theres a cost?
Old Nov 15, 2012 | 12:55 PM
Mine charged me $55. If you know some one with a drb III they can do it also.
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
robbyS
13
Dec 20, 2014 04:25 PM
jmerriman17
Nov 21, 2014 04:38 PM
