Glow Plug Driver
Old Nov 12, 2012 | 12:47 PM
mfmfim's Avatar
Default Glow Plug Driver
Hi,
I'm a newby here but I have a question. I have several issues with my K2500 but one of my pressing issues is it not starting in cold weather. I've changed the glow plugs out and they needed it. Yet I still have issues with it starting and yes, I have the block heater plugged in. This leaves me with the glow plug driver.
Can someone tell me what the part number is and how to change it out?
Thanks,
Old Nov 12, 2012 | 05:45 PM
racer55's Avatar
Need to know the year of the truck,there are more than 1 glow plug relay to choose from.
Also they are activated differently depending on year.
Have you checked for voltage at each glow plug when the glow light is on?
Each plug has a fusible link as well as the glow harness for each side of the engine has a fusible link.
Old Nov 12, 2012 | 07:28 PM
mfmfim's Avatar
It's a '94 K2500.
No have haven't check the voltage at each plug. I will do this.
Old Nov 12, 2012 | 07:47 PM
racer55's Avatar
AC DELCO Part # 212366
Alternate/OEM Part Number(s): 12496472 (GM)
To change it disconnect the wiring and remove it from the studs it is mounted to under the wiper motor at the drivers side rear of the engine.
Be careful not to disturb those studs because they go into the cylinder head water jacket and can cause a leak.
Note:1 of the heavy wires is always powered up(comes from a battery + connection),wrap it with electrical tape when removed to prevent a fire hazard.
Old Nov 14, 2012 | 11:18 AM
mfmfim's Avatar
I've ordered the relay, thank you.
Metz1234
Mar 3, 2016 10:20 PM
94chevy6.5
Tech Article Submission
Jun 16, 2015 12:45 AM
Texasthb
Mar 4, 2015 08:20 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
