Help I believe there's a short! 04 F-250
Old Nov 8, 2012 | 11:04 AM
audiophile's Avatar
Default Help I believe there's a short! 04 F-250
I initially had a problem with a terminal barely touching, so i replaced that, then my truck wouldn't start because the batteries were low. Then I charged them, and i was told they were bad so i replaced both the batteries and then had the alternator tested, and it was bad. So I replaced that. The truck ran great, then the voltage dropped and the batteries kept dying and voltage was under 12. now the batteries are flat dead. I do believe there is a short as I used a multi meter to test the positive end to touch ground, ex. the alternator, and I was getting continuity. So I think there is a short. I've tugged at a lot of wires and pulled all the fuses, still shorted.
HALP! I need to use my truck!
Old Nov 8, 2012 | 06:16 PM
poor boy,s toy's Avatar
maybe a stuck syliniod glow plugs or starter
Old Nov 9, 2012 | 11:37 AM
Mdub707's Avatar
More info about the truck would help. Any aftermarket electronic accessories? I see a lot of issues from aftermarket remote starts and alarms on these. Any work done recently on the truck? Did this problem just pop up out of the blue?
Old Nov 15, 2012 | 08:12 PM
fivepointohno's Avatar
i had a ground problem with not have enouugh grounds try and grounding the battery dirctly to the frm if that works add another ground and you will be good.
rah32860
Jul 25, 2015 11:11 AM
Jun 8, 2015 01:40 AM
yhatzee89
For Sale
Mar 1, 2015 09:03 PM
Feb 18, 2015 02:40 PM
KOMONER
Oct 6, 2014 01:14 PM
