need a little advice
Old Nov 3, 2012 | 08:15 AM
RTHSR's Avatar
Default need a little advice
engine starts then quits,after 2 or 3 starts will run normal idle 750 rpm,s then begins to idle up and down. When it idles up starts smoking. When you start from a dead stop engine begins to run rough and sometimes will stop.Check engine light does not come on. Any help with problem would greatly be appreciated. Thanks again for any suggestions
Old Nov 3, 2012 | 11:47 AM
Diesel Addict101's Avatar
How dramatic is the idle change? Is it really high when it starts smoking? What color is the smoke?
Old Nov 3, 2012 | 12:16 PM
RTHSR's Avatar
Default need a little help
It will idle up to 850 rpms. The color smoke is black. Thanks for helping out
Old Nov 3, 2012 | 01:47 PM
Interesting it wouldnt start smoking because of the rpms but it definitely sounds like you have a fuel delivery issue as well like its getting to much at an idle im still pretty new to cummins but i would monitor duel pressure if you can when its doing that and see if its jumping all over the place when it idles up
Old Nov 3, 2012 | 02:44 PM
Tyler@TWX's Avatar
FormerVendor
Check the map sensor. It could screw with idle and cause smoke, make sure the connections are good,
I would bet map sensor based on description
Old Nov 3, 2012 | 06:49 PM
RTHSR's Avatar
Default 04 5.9 cummins
Thanks Guy's for the info.
Old Nov 3, 2012 | 09:19 PM
South Texas Goat's Avatar
Air filter is clean?
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
lifted07sierra
Nov 6, 2014 08:24 AM
