Elite Stage-1 DIY Injector Kit
Has anyone heard of this/know anything about it? Seems like a cost effective way to bigger injectors.
https://www.elitedieselengineering.c...-Injector-Kit/
This is true, however, wouldn't larger/more nozzles increase the volumetric flow into the combustion chamber? Think about it like changing jets on a Holley, same OD to fit in the hole, but a different ID to change the flow characteristics.
Or do I need to put my linebacker helmet back on and sit in the back of the classroom again?
IIRC, a hot FICM tune will just about empty out the stock injectors. For the cost and hassle of changing out stock nozzles to a larger nozzle, a hot FICM tune would do the same at half the cost.
An injector body is a set size, despite what the nozzle will flow, a 135cc volume body injector doesn't go to 155cc's just by changing the nozzle...
I'm not saying it wont "flow" more, but the injector size hasn't changed. There are a lot of other factors to consider with the flow too, RPM's, pulse width, ICP
carid
Diesel Bombers Sponsors
Feb 9, 2015 07:12 AM
