leaf spring spacers
Old Oct 30, 2012 | 04:14 PM
82C206.2's Avatar
Default leaf spring spacers
I bought a nice set of 33x12.50x16.5 with wheels but when loaded they rub the top lip of fender well...think a leafspring lift block would be ok to keep my tires from rubbing...or can they slip out or break...just looking for a cheap fix
Old Oct 30, 2012 | 05:00 PM
Tyler@TWX's Avatar
FormerVendor
As long as you replace the block and dont try to stack them you will be fine
Old Oct 30, 2012 | 05:02 PM
racer55's Avatar
The lift blocks are usually located by the hole in the spring perch and a peg and matching hole in the block and the spring stack centering bolt-the tension of the U bouts also helps keep them in place and there is almost never a problem.
Something to consider is that the lift blocks should be tapered to maintain the pinion angles relationship with the trans tailstock angle,a big lift distorts the driveline angle a lot.
Old Oct 30, 2012 | 06:56 PM
82C206.2's Avatar
what about using coil spring spacers on the front or will the diesel be to heavy for the spacer
cummins.1.5.3.6.2.4
Sep 20, 2015 01:47 AM
Aug 7, 2015 05:10 PM
2FordStrokers
Tire, Wheel & Suspension
Jan 5, 2015 09:23 PM
myago92
Oct 17, 2014 08:50 AM
Sep 29, 2014 03:00 PM
