Bone stock but I'm gonna play...
Old Oct 29, 2012 | 09:29 PM
Meierznutz's Avatar
Default Bone stock but I'm gonna play...
I just picked up a 95 12v P-pump 2wd truck and have some stuff left over from my old '02. I am going to swap to the hybrid HX-35/40 turbo I built for the '02 and see what it does. Got 42# out of it with an Adrenaline chip and Banks exhaust and brake on that truck.
So what do I need to do to get it to spool on this truck. I know I need to turn up the star wheel and move the plate forward but should I get a plate for it or will that be enough?
The trans in the truck surges and is weak so I know I am going to pop it, but hey....there is the excuse for billet!
Old Oct 30, 2012 | 07:33 AM
angelic0-'s Avatar
yank the plate, and crank the starwheel...
the HX35/40 will spool easily as the P7100 trucks more fuel than the VP...
you might want to set timing to 16° aswell...
Old Oct 30, 2012 | 05:49 PM
Fox's Avatar
Fox
isn't the stock pump set at 15.5? I hear most people bump up to 19*....
Old Oct 30, 2012 | 08:24 PM
angelic0-'s Avatar
stock is 13,5.... stock headgasket and headbolts will be safe @ 16,5
Old Oct 30, 2012 | 08:37 PM
WILDKING's Avatar
Default 5.9 cummins 12 valve stock
I have my timing cover off, to put in new seal. How do I advance timing to 16.5? I am also installing 4000gsk governor springs and 60# valve springs, how do I keep the valves from falling in the cylinders?:
Old Oct 31, 2012 | 07:56 AM
Drothgeb's Avatar
Set the piston at TDC on the cylinder that you're replacing the springs.
Old Oct 31, 2012 | 09:29 AM
Fox's Avatar
Fox
Pardon my ignorance... but what's the best way to determine that with no spark plug port?
Old Nov 5, 2012 | 03:55 AM
WILDKING's Avatar
When both exhaust and intake valves are at their highest point the piston is all the way up.
Old Nov 5, 2012 | 08:43 AM
Meierznutz's Avatar
You can also get a Diesel Compression tester....it has a fitting to hook up an air supply through the Injector hole. The air presure will hold the valves in the closed position while you work.
06dodgecummins
Jul 13, 2015 11:24 PM
wannadrag
May 25, 2015 03:07 PM
Mar 27, 2015 07:20 PM
mkeithmcguire 73
Mar 22, 2015 07:46 PM
Sophia'sJustice
Mar 5, 2015 04:06 PM
