Just wanna know!
Old Oct 29, 2012 | 08:17 PM
BlowinBlackNotBroke698's Avatar
Default Just wanna know!
Hello everybody, im new to this site. Im 16 and have limited money but I would like to know what is wrong with my 1992 6.5l turbo diesel. It starts fine when cold, but when gets hot just turns over till the batteries are dead. I have some, but minimal knowledge of diesels. My 2 main ideas is 1. IP pump 2. Starter/Terminals. Iv tried pouring water on the IP pump and it seems to help, BUT iv also tried the 2000 RPM test I heard about and also when the truck turns over smoke puffs out of the exhaust. This tells me that the fuels system is working as designed. Could it really be the starter, or should I just get ready to shell out $1,000+?
Old Oct 29, 2012 | 08:22 PM
West MI Mudder's Avatar
I heard that one symptom of a bad Injection pump is that it will start fine cold, but wont start hot. So im leaning more towards the injection pump. Sorry about your bad fortune.
Old Oct 29, 2012 | 08:36 PM
Mayhem's Avatar
When having warm start up issues carry some water with you and pour cool water on the IP if it fires up then it is the IP this is called heat soak when this happens oh what color smoke are you having??
Old Oct 29, 2012 | 09:07 PM
Thanks guys, and black. How hard is changing the IP pump on my own vs. taking it to someone?
Old Oct 29, 2012 | 09:16 PM
Mayhem's Avatar
On your truck should be pretty easy depending on your abbilities as a mechanic compared to a 6.5 with electronic injection just a matter of lining up the timing marks
Old Oct 29, 2012 | 09:23 PM
Alright, thanks
Old Oct 29, 2012 | 10:41 PM
racer55's Avatar
A weak or slow turning starter can significantly affect the hot start situation as well.
Old Oct 31, 2012 | 07:55 PM
Ok I got both batteries load tested one came back bad with only 451 CCA when it was supposed to have 850 CCA. Replaced it, got home. Truck is still just turning over, but isnt losing power like it was. What else could it be, besides the IP pump?
Old Oct 31, 2012 | 08:52 PM
racer55's Avatar
Could be a worn IP when hot having too much plunger clearance to build enough pressure to pop off the injectors properly at cranking RPM-that is why the water trick helps because it shrinks the housing reducing clearances.
For the short term a manual glow mod might get you over the hump for warm/hot starts by having the glow plugs operate at your command-google "Glow Plug Over Ride Modification".
The manual glow mod will also help with low compression from a worn out engine.
It is cheaper to try for the short term than an IP,and if/when you do get to the IP it will still be helpful.
Poor spray patterns from worn out injectors also affect smoking and hard starting-the general rule of thumb for injectors is rebuild/replace every 100,000 miles.
Old Nov 1, 2012 | 05:42 PM
SFC MOHN's Avatar
Default good answers
When overseas we encountered the same problems you mentioned. Being the old guy the problem was given to me . All our engines are mechanicle no electronic PMD only ecu. I hate to say it but my money is on your needing a replacement IP. Pouring COOL water over the IP will get you by for a while, look around for a used , tested unit and remember to get new gaskets for the intake and crowfoot wrenches for the injection lines.
