how to get more hp out of my 95?
Old Oct 27, 2012 | 08:02 AM
Cumminsaddict's Avatar
Default how to get more hp out of my 95?
i have a 95 rclb 5speed it has a tst number 8 fuel plate full forward,star wheel forward,cai,diamond eye 4 inch tb, everything else is stock. is there anything more i can do to increase my power (not smoke) without slipping my clutch?
Old Oct 27, 2012 | 08:18 AM
angelic0-'s Avatar
you can try your luck with a 4k GSK...
but i suggest getting #60 valvesprings while you're at it...
it isn't as hard as you might think to replace these parts on your truck, a friend of mine did it without removing his head...
but i strongly suggest a new clutch, what are your plans for the truck ?
Old Oct 27, 2012 | 12:36 PM
CR9712v's Avatar
what you do is get you some harnesses and strap some Clydesdales to the front of that bad boy!
Old Oct 27, 2012 | 02:12 PM
long term plan is to build it completely and shoot for around 600hp but until funds aremore plentiful i want it to run as good as possible without destroying parts
Old Oct 27, 2012 | 02:41 PM
angelic0-'s Avatar
600hp (not WHP) is possible with a stock motor and a good set of twins, good injectors and timing... without destroying parts... you might pop your headgasket.... but then you just install studs and a stronger gasket
Old Oct 27, 2012 | 09:43 PM
do you think 18 to 20*, 5x018's, hx35 over s400, SBDD, and arp studs and a thicker head gasket would get me there?
Old Oct 28, 2012 | 12:06 AM
angelic0-'s Avatar
the HX35 is not really a good "over" turbo, i replaced my HX35 for a HX40 because it would have caused drive pressure problems...
You shouldn't have too much trouble obtaining a HX40, i'm running a HX60 under it, that with 4k GSK, #60 Valvesprings, 5x.018s, SBDD, ARP studs and a thicker gasket... and 22,5° timing... should put you in the safe ~750hp zone... and be streetable...
Old Oct 29, 2012 | 11:27 AM
dfiperformance's Avatar
FormerVendor
For 600hp. a 62/65 and a S475 will get you there and past if you want. A set of 5X0.016s will also get you there but it will be easier to get there with some 5X.018s. And the 5X.018s will leave you more room to grow. I would highly advise studs and a 4K GSK along with valve springs and a good lift pump. I would look at an Aeromotive A1000.
Chris
