code 21 for TPs
Old Oct 24, 2012 | 12:45 PM
chevyman0013's Avatar
Default code 21 for TPs
Chevy quad cad 3500 6.5 turbo diesel has the obd code 21. Its for a throttle position sensor high circuit. Isnt this code most likely for the TPS sensor. I should just replace the sensor right? If not how do i check it?
Old Oct 24, 2012 | 03:34 PM
racer55's Avatar
It is an APP code.
Accelerator Peddle Potentiometer -fuel peddle.
There are a series of variable resistors like the fuel gauge in the peddle that report to the ECM.
New peddles/sensors are expensive dealer items.
Try cleaning inside the sensor with electrical cleaner and then WD 40,or get 1 from the wreckers.
Old Oct 24, 2012 | 06:28 PM
Mayhem's Avatar
Originally Posted by racer55
It is an APP code.
A PPS is not a dealer only part I replaced mine earlier this year when my truck was acting up it had no throttle resonse what so ever got mine here Accelerator Pedal Pad Ac Delco 213-2820
Been like a new truck ever since I made the mistake of getting a Junkyard PPS for $75 had the same symptoms as before junkyard only offered a exchange no refunds and if junkyards are like they are here there are not many 6.5s in them so do what you want but I feel like I would have saved time and money if I would have ponied up to begin with and bought my PPS new to begin with
Old Oct 24, 2012 | 10:12 PM
Guys thank you for your input but i dont see when this has to do with my Tps Sensor...
Old Oct 25, 2012 | 07:06 AM
Mayhem's Avatar
Unplug both of your batterys for 10 minutes it will reset your computer if you get that code again replace sensor
Old Oct 29, 2012 | 11:22 AM
racer55's Avatar
APP=TPS on electronic IP trucks.
Sorry,just getting used to this forum and found the year of truck in your sig.
On a 93 the TPS is not the APP,it is mounted to the side of the IP throttle linkage.
Check connections and resistance in the sensor,it may have a dead spot and need replaced.
The code chart caters more to the electronic IP's,I will need to check an older manual for more relevant info since it has been a long time since one of those trucks passsed through.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
