what the crap. please help.
Old Oct 24, 2012 | 10:51 AM
1st Diesel's Avatar
Default what the crap. please help.
Just bought new ficm. Still sitting at dealer. Im not getting that normal buzz when the key is first turned on and it is not wsnting to fire up. My old ficm was a 7 pin amd they gave me a 4 pin. they said there wouldnt be any problems. Any suggestions? Its an 03 fx4 137,000 miles, last 8 months ive done, 3 injectors, 2 batteries, hpop, icp, ipr. Im lost.
Well i just got her to fire when the motor was a little over the cold line. only mod is a 5" straight pipe
Ok now. Update is she took forever to start. But once it did, i had to blow all the smoke out of her. All the misfires mustve had excessive fuel built up. But after running her, she runs like a champ again. If your gonna stroke it, POWERSTROKE it. Lol
Ok well, she was running great. But still apparently a hot no start condition.
Last edited by 1st Diesel; Oct 24, 2012 at 10:51 AM. Reason: Automerged Doublepost
Old Oct 24, 2012 | 12:27 PM
Diesel_Daddy6.0's Avatar
Hot start problem is related to the oil system...standpipes, dummy plugs, STC fitting, IPR. Standpipes and dummy plugs are easy, right under the valve covers, STC and IPR on the other hand are a bit more of a pain in the ***.
Old Oct 24, 2012 | 12:29 PM
1st Diesel's Avatar
I just did the ipr, icp and hpop about 4 months ago. They should be good. But mines an 03 and they dont have STC fitting on these years.
Old Oct 24, 2012 | 12:45 PM
Did you do standpipes and dummys?
Old Oct 24, 2012 | 12:54 PM
1st Diesel's Avatar
I just looked it up and this year apparently doesnt have dummy plugs. But ive never done the stand pipes. I was looking them up. Is that about your only guess? I just dont wanna throw a bunch of cash at it. O$ everything ive found it sounds pretty accurate.
Old Oct 24, 2012 | 01:10 PM
About $60/side
Old Oct 24, 2012 | 01:16 PM
1st Diesel's Avatar
Yea i just called thr dealership. Id have to order them. But sucks cause i wont have time to do them till next week. Have my air force reserve weekend this weekend.
Old Oct 24, 2012 | 01:39 PM
It's not too bad to do. What tends to happen is over time the o-rings on them get old and leak (reason it's only a hot-start issue is because when the engine is cold the oil is thick enough to not leak, but when it thins out you get problems)
Old Oct 24, 2012 | 04:16 PM
Mdub707's Avatar
I'd be trying to monitor ICP actual and ICP desired before diving in, the earlier trucks didn't have near the issues with high pressure oil leaks. HPOP's seem to die a little more often and a little more suddenly, but if it was dead it wouldn't have started.
Are you sure you're getting a good charge to your batteries?
You can use any year FICM on any year 6.0, 4 pin or 7 pin, doesn't matter. They don't sell 7 pins anymore though, they're all the newer 4 pins.
Old Oct 24, 2012 | 08:44 PM
1st Diesel's Avatar
Ok. Well i did the icp, ipr and hpop about 4 months ago. So it might be time to do the stand pipes anyways just to get the updated ones in. It starts just fine when the needle is about 1/4 warm. But over that and its a fight.
