flywheel question???
Old Oct 22, 2012 | 04:13 PM
72fj's Avatar
Default flywheel question???
is the flywheel for a 6.5 the same as for a 6.2.is there a different balance.any help will be appreciated.thanks chuck
Old Oct 22, 2012 | 05:18 PM
Mayhem's Avatar
Are you talling abou manual transmission flywheels or automatic ring gears the automatics use the same ring gear the 6.2 had a single mass flywheel while the 6.5 had the dual mass flywheel but one will work in the other but IMO the single mass flywheel is the way to go it's a good idea when shuting off the vehical that you hold in the clutch to keep it from kicking back on the engine.
Old Oct 22, 2012 | 05:25 PM
72fj's Avatar
is the manual trans flywheels the same, no auto trans stuff. thank you.
Old Oct 22, 2012 | 05:37 PM
Mayhem's Avatar
no they are different read above post
Old Oct 23, 2012 | 10:12 PM
racer55's Avatar
Only some 6.5's came with a dual mass flywheel and the solid and dual mass flywheels are interchangeable between 6.5's,the difference is the solid flywheels trucks had a balancer on the trans output shaft for vibration-most who have switched do not complain without the balnacer.
Now to answer the OP's question,the bolt pattern on late 6.2's and all 6.5's are the same and interchangeable,the early 6.2's had a 2 piece rear main seal and a different crankshaft bolt pattern.
PA 24valve
Aug 31, 2015 06:08 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
TMP025
Chevy/GMC Duramax 01-04 LB7
Feb 16, 2015 12:27 AM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Dec 11, 2014 07:29 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
