repeat issue, still no answer
Old Oct 21, 2012 | 10:32 PM
IH5152's Avatar
Default repeat issue, still no answer
I read the post on Jan 30,2012 by Diesel4Dummies. I am having the same issues of stalling dying and running when it wants to (kinda like my wife). Have fuel to fuel filter and water seperator 't'. Open the 't' fuel runs, shut it and starts for few seconds and dies. Ran fine earlier in the day. Leaning toward stuck fuel shut off sylanoid or oil pressure sending unit not turning fuel shut off slanoid on. Crazy seemed to know his stuff and would like his or anyone elses input on this problem. Doubt its the PMD since it was a cold engine and 78 degree day. HELP my wife is loosing sleep because of my research. Thank you, Jeff.
Old Oct 22, 2012 | 07:26 AM
Mayhem's Avatar
What codes are present??? is the truck OBDI or OBDII the more info we have the better
Old Oct 22, 2012 | 05:22 PM
IH5152's Avatar
Default More Information
I havn't check for codes yet. And what i learned last night it is the OBD1. It's a 95.
Old Oct 22, 2012 | 05:40 PM
Mayhem's Avatar
Use this link follw the directions and report back with what codes and we will try and figure out whats going on
http://www.extreme-check-engine-ligh...%20Decoder.htm
Old Oct 22, 2012 | 06:13 PM
IH5152's Avatar
Default checking for codes.
Thanks I'll try that and get back here with the results.
I have the code 35,84,99. and the darn thing decided to start and run fine after checking codes. I even shut it off and it restarted.
Old Oct 22, 2012 | 07:00 PM
Mayhem's Avatar
Im not for sure but it sounds like may be having OPS issues if you have more symptoms like the one you are having I would replace it but do get a AC/DELCO part stay away from anything BWD as these are crap IMO
Old Oct 22, 2012 | 07:09 PM
IH5152's Avatar
Default ops may be the answer.
If i read right the ops is the oil pressure sending unit, and that controls the fuel shut off sylanoid on the injector pump is this correct. could it be the pmd since its still located on the injector pump. How can a person check the OPS and the PMD before replacing them. Thanks again for your help I'll be on for a while yet tonight to correspond on this issue.
Old Oct 22, 2012 | 07:39 PM
Mayhem's Avatar
The OPS controls the LP(Lift Pump) if its not readind at least 7 PSI it will shut off the LP causing the engine to stall or die,However the PMD in its stock location is a very bad place it will not give codes when it's on the way out anywhere under the hood IMO is a bad place I have mine mounted behind the front bumper as do alot of other electronic 6.5 owners Deisel Care in Memphis is where I got mine from they are very knowledgeble and make their own products for the 6.5 along with the relocation cable
Diesel Care and Performance Inc
hope all this helps
Old Oct 22, 2012 | 07:49 PM
IH5152's Avatar
Default Yes this is helping.
If im getting fuel out of the filter cap and the water seperator T on the thermastat housing when ever i crank the engine whether it starts or not, does that tell me the lp is working along with hearing it. Also i should add that i replaced it less than a year ago.
Old Oct 22, 2012 | 07:55 PM
Mayhem's Avatar
OK that pretty much rules out the OPS i was leaning towards the PMD but didnt want to overlook the $20 part that will make the truck stall die as well if you decide to replace the PMD I want to ad that you should get the biggest heat sink you can get as to disapate the heat from it bigger heat sink is better
