WHICH FUEL PLATE WOULD BE BEST
Old Oct 17, 2012 | 07:06 PM
monstercat's Avatar
Default WHICH FUEL PLATE WOULD BE BEST
I have a 98 12 valve quad cab do mostly towing a 11000 lb 5th wheel I have asked 3 different Diesel Mec. each have told me different things one said a #11, one a #10 would be better then a #11 just don't put it as far forward unless you want more power and another told me to put in a #6.
Which one would be best for me and why?
I think you need a lettle more info I have 4x4 with a manual trans NV4500, I have put in a HD Clutch. and have a BD exhuast break, 60lb exhuast valve springs.
Last edited by monstercat; Oct 17, 2012 at 07:06 PM. Reason: Automerged Doublepost
Old Oct 18, 2012 | 06:18 AM
angelic0-'s Avatar
#0 plate, full forward, tune your afc...
Not to hard to make it yourself...
The foot travels from the bottom and goes up, so the lowest part of the plate tells you how much fuel is retarded at that rpm..
i did a #0 for quicker spool-up, tuning your AFC is also VERY important...
as long as you don't advance timing on your pump, and you don't have a 4k GSK kit or above, given that it has stock timing, you will be fine with the mods you have...
the starwheel and smoke screw will control pre-boost smoke...
mine was pretty clean when i was at your level with a #0 plate, stock timing and good AFC tuning
you will have to upgrade your clutch though, because when you start.. you can't stop..
you can make around 350-370whp with the stock charger...
Old Oct 19, 2012 | 12:47 AM
1stgenblowingsmoke's Avatar
I have a 100 plate and love it. Ran no plate for a while but worried a lil with towing on EGT's.
Old Oct 20, 2012 | 12:57 PM
turbo2332's Avatar
a zero full forward is like running plateless. i ran a #6 for years until this last turbo upgrade.
Old Oct 26, 2012 | 08:22 PM
angelic0-'s Avatar
Running plateless vs Running w/ #0 plate full forward is different...
i should know mine coughed up extra 40hp on the dyno....
Old Nov 1, 2012 | 08:41 AM
stokes44's Avatar
Default plateless
which one gave you the 40 hp?
Old Nov 16, 2012 | 11:47 PM
lodal cummins's Avatar
I say go for a ten. I think egts are going to be a little on hot side with your weight if ya go with a 100 or zero running a stock charger.
Old Nov 17, 2012 | 04:25 AM
angelic0-'s Avatar
running plateless compared to running with a #0 full forward...
Old Dec 6, 2012 | 06:34 PM
monstercat's Avatar
I ended up getting a #10 fuel plate, and will put a 4" exhaust on soon
Old Dec 7, 2012 | 06:41 AM
angelic0-'s Avatar
if you want more..... get gauges first...
