6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
new in this
Old Oct 17, 2012 | 03:24 PM
elchicharo2000's Avatar
Question new in this
Hello I have a 06 E350 6.0 my boss said everything start when somebody change the turbo the truck start missfire at all the cil, he change the injectors and run better but he have a missfire at #7 some times he reflash de compu and the same he send the module to rebuild and the same problem, miss at # 7 cylinder and is more comun when is hot but no all the time i don't now too much about diesel but i whant to tryed fix if somebody help me I apreciated all the help thanks
Old Oct 17, 2012 | 03:30 PM
Mdub707's Avatar
Dude... you have a post here already, literally right below this one, and we already answered on it....
Old Oct 17, 2012 | 04:15 PM
I'm sorry but I no si ur answer
yes i see ur answer is on other forum i go try i let u now
Last edited by elchicharo2000; Oct 17, 2012 at 04:15 PM. Reason: Automerged Doublepost
Old Oct 18, 2012 | 11:13 PM
Hello again i have to replace the injector but i see is a lot of work it's no matter what i go to try the funy think is the pasanger side
Old Oct 19, 2012 | 10:48 AM
Mdub707's Avatar
If you're pulling the valve cover for that side, my advice would to be put all new o-rings on all of the injectors on that bank. Sometimes an injector will leak past an o-ring and falsely cause the other injectors to throw a code. So it could be injector 1 we'll say (hypothetical) that is having issues, but causing other injectors to pop up. So instead of pulling the valve cover, fixing #7, putting it back together and all of a sudden you've got codes for a different injector in that bank... spend the few bucks and do the o-rings on all of them. They're not expensive to do.
Old Nov 1, 2012 | 03:51 PM
Hello thanks for the advise I due and I change everything like u said but still I have the miss fire on No. 7 But now the missfire is about 10 o 15 minutes and only 1 time u feel I take long time because I have to work on diferents cars but I still try, PS when I take some parts I found 2 bolts for the fuel pressure rail losse,
Old Nov 2, 2012 | 07:42 AM
Mdub707's Avatar
Test your FICM. The test procedure is at the top of the 6.0 page.
Old Nov 2, 2012 | 04:54 PM
thanks and let u now the result
