Wont run right
Hi i have a 1997 ford f-250 powerstroke 7.3L diesel this is my first diesel truck. the truck quit i found out the pre-heater for the fuel quit and the related fuse burned out so after i changed some parts like the pre-heater, fuse, fuel filter, batteries, fuel pump on engine all new parts. Now the truck starts only after it sits awhile and only when i hold the throttle at 1000 rpm and if i let go of the throttle it will quit and be a pain to start again unless it sits for awhile and only when i hold the throttle. I did do a CanOBD2 tool test on the truck and it came back (0) no problems. I have went over the parts i replaced several times to make sure i did them right (double checking) no leaks that i can see.
need some help.. thank you
Sounds like the IPR is plugged or you have an ICP issue...
First thing I would do is remove the IPR and clean it.
IF that doesnt help you need to get a scanner on it and watch ICP pressures and duty cycles while cranking.
https://www.dieselbombers.com/99-03-...l-rebuild.html
vin_diesel
Mar 1, 2016 01:43 PM
Josh923
Sep 10, 2015 11:16 AM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
wvwelder89
Nov 20, 2014 10:26 AM
