Diesel fumes through a/c?a
Old Oct 12, 2012 | 05:29 PM
Whitman41's Avatar
Default Diesel fumes through a/c?a
I have had my 05 f250 now for about three months and I'm not one to use heat or a/c much I have been running it lately and have noticed a strong diesel smell in the cab when it is on. Is that normal or what could be causing it thanks guys.
Old Oct 12, 2012 | 05:42 PM
Farmboy 2.0's Avatar
Your up pipes arent leaking are they?
are*
Last edited by Farmboy 2.0; Oct 12, 2012 at 05:42 PM. Reason: Automerged Doublepost
Old Oct 12, 2012 | 08:21 PM
Curry's Avatar
Happened to mine a few months ago. Cracked y pipe. Does it smoke at all? or a loud whistle? Other than turbo?
Old Oct 12, 2012 | 08:29 PM
Whitman41's Avatar
No no smoke at all or whistle out of ordinary I don't guess. Kind of new to the whole diesel
Old Oct 12, 2012 | 08:44 PM
biged681985's Avatar
U say diesel fumes, are u referring to the smell of raw fuel? Could be a fuel leak. If items smell of exhaust fumes I would bet it is cracked up pipes
The guy who is tired of driving a suburban
Old Oct 13, 2012 | 07:31 PM
Whitman41's Avatar
What does that cost to fix and what else could it mess up. Also how do I diagnose it. Would now be a good time to get the egr delete since its coming apart anyway
Old Oct 14, 2012 | 09:46 AM
Mdub707's Avatar
There's two different outcomes here, but you need to diagnose it first. Throwing parts at it wont help.
Is it raw diesel like from the pump kind of smell, or does it smell like fumes, like burnt diesel?
Old Oct 15, 2012 | 09:47 AM
c-tane's Avatar
When my excursion is stopped at a long signal I get exgaust fumes in the cab as well. I would have to guess that mine is exgaust fumes based on the sweet smell. It does not smell like raw diesel. I am curious too, If anyone has sugestions.
Old Oct 15, 2012 | 11:41 AM
Mdub707's Avatar
sweet smell is usually coolant. Raw diesel smells like what comes out of the pump at the fuel station. Burned stuff like what would be coming through up-pipes is a burnt diesel smell, like what normally comes out the exhaust. That would be cracked up-pipe most likely. If it smells like raw fuel it's usually a leak up by the filter housing. Neither one of them smell "sweet"
Old Oct 15, 2012 | 08:11 PM
Whitman41's Avatar
Well smelt it then exhaust pipe then tank then exhaust pipe then vents again. Had a diesel mechanic smell vents he said its exhaust smell so what's next
