DURAMAX PROBLEM
Old Oct 5, 2012 | 07:13 AM
duramax2002's Avatar
Default DURAMAX PROBLEM
SO HERES THE DEAL..RECENTLY REPLACED INJECTORS IN MY 2002 DURAMX. STARTED AND RAN GREAT THEN AFTER A SHORT DRIVE THE THING WONT START WITHOUT FLUID. ANY IDEAS ON WHAT COULD BE CAUSING THIS..RUNS GREAT AFTER THE ETHER SHOT BUT DON'T WANT TO CONTINUE THIS..IS THERE A FUSE OR A FUSEABLE LINK THAT COULD B BLOWN?
Old Oct 17, 2012 | 03:27 PM
Truck Guy99's Avatar
Ask in the Duramax Lb7 forum. You wont get nobody that would know the answer to that in the website discussions.
Old Oct 17, 2012 | 06:46 PM
turbostang7's Avatar
Could be lots of things, cp3 bad glow plugs, glow plug relay, connector bar for gp, and possibly bad new injectors plus the common fuel issues
Sent from my DROIDX using Tapatalk 2
Old Oct 17, 2012 | 08:20 PM
PSD-BLACK-CLOUD's Avatar
Stop shooting either in it.
Old Oct 18, 2012 | 10:34 PM
Ltk's Avatar
Ltk
Old Oct 18, 2012 | 11:42 PM
TDFDiesel's Avatar
Don't start an engine on starting fluid... BAD idea....
What mods do you have? Have you primed it?
Old Oct 20, 2012 | 05:52 PM
mikekoz's Avatar
Im having the same problem, replaced the injectors and cp3 pump. if the truck sits for a bit it looses prime and i would hit the primer a few times it would be fine. now it will run for a few mins and die. I was also wondering what the problem could be? I also did the rebuild kit for the filter housing still loosing prime
Old Oct 24, 2012 | 11:31 AM
so after more hair pulling thought it might be a bad cdu. i do have power in but nothing at the injectors.is it possible to read the voltage at the injector? if the cdu went bad would it show up as the original problem of one injector going bad? and what would be the best way of checking this out.
Old Oct 24, 2012 | 11:55 AM
Yours could be a cracked filter housing, its a common problem. Usually you can't see the crack at all
Old Oct 24, 2012 | 03:38 PM
dont see any fuel anywhere (like a leak) new filter on it and seem to have pressure on the out side of it. thing ran fine for a couple of days..does not matter if i prime it thats why i wondered if the edu could be bad.
