problem runs bad after new injectors and new injector pump
Old Oct 2, 2012 | 08:21 AM
tillett70's Avatar
Default new problem runs bad after new injectors and new injector pump
runs bad and idles rough after new injectors and new injector pump. Could it be timing or injectors? thanks
Old Oct 3, 2012 | 12:22 AM
Turbine Doc's Avatar
Okay how long you been trying to run it, possibly air in it still, and also describe the procedure you or your mechanic used to time the IP after replacing it.
Old Oct 3, 2012 | 08:09 AM
tillett70's Avatar
ran for about 10 minutes off and on and we lined it up and put right back were the old IP was
Old Oct 4, 2012 | 11:39 PM
blacksally's Avatar
make sure all the injector lines are tight if leaking any fuel will make it run rough
Old Oct 24, 2012 | 09:35 AM
racer55's Avatar
What year is the truck?
