Dana
Old Sep 22, 2012 | 08:17 PM
VAW's Avatar
VAW
Default Dana
What do you guys think is the best Dana axle? I'll be producing around 700+ horsepower and the truck will mainly be used for pulling a trailer every weekend?
Old Sep 23, 2012 | 01:03 AM
cummin_un_glued's Avatar
FormerVendor
D80 i've broke 2 dana 70s at less power then that but i was sled pulling
Old Sep 25, 2012 | 11:34 AM
CR9712v's Avatar
i destroyed a 70 riding down the street... get an 80
Old Sep 25, 2012 | 02:29 PM
VAW's Avatar
VAW
I've heard a lot of good out of the 80's. Has anybody ever used super 60s?
Old Sep 25, 2012 | 03:39 PM
FormerVendor
At 700hp your going to need an 80. The pinion is the weak point in the 70 and you would have the same problem with any variation of a d60 that still used a 60 r&p.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Sep 27, 2012 | 11:02 AM
1AMatt's Avatar
Site Sponsor - 1aauto
X2... With that much HP D80 would be best
Old Sep 27, 2012 | 09:25 PM
Bigmark65's Avatar
D80
Old Nov 18, 2012 | 03:53 PM
Hurst89's Avatar
What about a 110 axle from a 4500/f450? Quite a few gear ratios available as well from aftermarket and dana. They are a square tube axle with a 12.something R&P. Should take the abuse. Only thing would be they are dually axles with 10lugs or large 8 lugs, so that could be a problem. Definitely not as cheap as an 80 conversion, but a lot heavier built.
Hurst
Old Dec 2, 2012 | 12:20 PM
VAW's Avatar
VAW
Has anybody used the 110 for high horsepower?
Old Dec 4, 2012 | 05:57 PM
VAW's Avatar
VAW
What front axle?
woodsman27
May 23, 2015 10:16 AM
tractormandan
Wanted To Buy (WTB) - Used
May 9, 2015 08:44 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
KYLEBOY
Jan 18, 2015 06:36 PM
gyayo2012
Nov 15, 2014 08:11 PM
