07 cummins with p2509 code
Old Sep 19, 2012 | 03:43 AM
cjt8569's Avatar
Default 07 cummins with p2509 code
Have a 07 ran 2500 5.9 cummins... ats intake..smarty tuner...guy just put a fisher plow on truck brought it to me its coding P2509 ecm/pcm power input intermittent herd of problem
before being a ground wire or batt but any imput or has anyone else had the same problem?
Old Sep 19, 2012 | 12:55 PM
Farmboy 2.0's Avatar
Did you have to remove any factory grounds when you installed the plow? If you did they may not be making a good connection causing this issue.
Old Sep 23, 2012 | 09:21 PM
cjt8569's Avatar
Well after going through the grounds tested batterys found one good and one tested bad replaced with new battery cleared codes put tunner back in and 300 miles plus no cel back on...so check batterys if you get this code
Old Oct 25, 2012 | 09:10 PM
minncountryboy's Avatar
Checked my batts there good now I'm gonna clean up the cables n hopefully it goes away... Sure does mess with the truck.. mines messing with my trailer brake controller, my radio, won't let the truck start sometimes.. doesn't work the grid heater till after the truck is started..
Old Oct 25, 2012 | 09:18 PM
cjt8569's Avatar
Check all your grounds to the motor/chassie make shore there all clean and dont have any green spunk on them...took me a while but i cleaned them all and found a few that were iffy..best of luck alson check ur batt terminals found drivers side pos cable to ne bad at the joint were it goes over to secondary batt
Old Oct 25, 2012 | 09:24 PM
Alrighty ill be cleaning the cables tonight.. checking everything else in the morning.. it just puzzled me cause in a matter of ten minutes mine went from running good to fussy to a tempermental b**** with a could after I changed the oil and fuel filter
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
upnorthwelder
Sep 16, 2015 04:50 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
