ABS
Old Sep 10, 2012 | 03:49 PM
paxlaser's Avatar
Default ABS
Got another problem. My ABS light flases all the time. I first noticed this when I used my programmer to set it back to stock. I loaned the program to a friend and I just got it back and it pops codes U20EO and U2032. Anybody have a listing for these codes?
Old Sep 17, 2012 | 07:42 AM
paxlaser's Avatar
No luck on find out what the codes mean. This weekend I replaced the sensor in the diff. No change. I did find the wires going to the diff sensor and been rubbing on a mounting bolt and had rubbed through the insulation. The wires are intact with some strands broken so I just taped it together. I think I'm going to pull the fron wheels next to look at the sensors and wires. ABS module was replaced 6 months ago at the stealership for $900. Who needs ABS anyway? I just want that flashing light to go away!
Old Jan 4, 2013 | 12:34 AM
paxlaser's Avatar
I forgot to update this. The light was because of my programmer. I load the bully dog to a friend for trouble shooting his ford but i had to revert to stock in order to set it up for a different truck. setting it back to stock told the computer the wheel diameter was zero inches. Set the tires to the correct size and the light went out.
cjt8569
Sep 29, 2015 06:39 PM
asajay
10
Sep 8, 2015 10:40 PM
Radioking1777
Jun 9, 2015 04:13 AM
Gitana
Nov 25, 2014 06:25 PM
ValleyF250
Nov 1, 2014 07:56 PM
