help with an injection system
Old Sep 5, 2012 | 11:51 PM
XTREMIST's Avatar
Default help with an injection system
have an 06 ram 3500 (5.9 cummins). just finnished putting in new injectors and tubes, an airdog 165 and a h&s mini max chip with pyro kit and when i went to start the truck it just turns over without even trying to fire.... i bled the lines out up to the CP3 pump and after that pump, i was getting frustrated so i even cracked the injectors themselves, everything is getting fuel but the truck will not start. no smoke out of the exhaust to show any type of combustion.... i guess it has to be an electrical problem but im not really sure where to start, does anyone have any pointers, advice or tips ? id really appreciate some help....
thanks
Old Sep 6, 2012 | 07:31 AM
Have you tried it without the Mini Maxx?
Luke
Old Sep 6, 2012 | 07:47 AM
biged681985's Avatar
Do not ever crack the high pressure side of the cr injection system. That could be very dangerous
Old Sep 6, 2012 | 07:49 AM
So u put all of that on at the same time?
Old Sep 6, 2012 | 07:56 AM
XTREMIST's Avatar
I didnt bother plugging the mini max in, just installed most of the components etc. i left it unplugged from the obd2 port. And i realize that its dangerous being under 24000 lbs but i couldnt figure any other way to see if there was fuel at the injectors....... Im wonderin if theres a fuse or relay blown...?
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
moneypitk5
Feb 12, 2015 11:01 AM
