coolant sensor??
Old Sep 5, 2012 | 06:19 PM
roylb7's Avatar
Default coolant sensor??
few weeks ago i started my truck and after driving a few miles my low coolant light came on. was almost to work so i rode it out and watched the temp gauge closely.. after it cooled i went out and checked the resevoir and it was full. took it home and no light. its been coming on, on and off the last few weeks and the temp gauge holds solid and the water level never changes. so im wondering if there is a sensor or something that has gone bad or what my problem may be. im sick of seeing that light pop up every other morning.
Old Sep 6, 2012 | 03:16 AM
2004LB7's Avatar
the sensor is on the bottom of the overflow tank. You can find it if you trace the wires. Check the level before starting the truck in the morning when you would normaly get the low coolant message and see if it is low then
Old Sep 7, 2012 | 06:18 PM
roylb7's Avatar
the level never drops
Old Sep 7, 2012 | 07:55 PM
2004LB7's Avatar
sounds to me like you have a break in a wire somewhere or a bad sensor. you could try jumping the terminals on the connector at the sensor and see if the "low coolant" message does not come on. you would have to do this before starting the truck as the message only gets reset once you turn it off. if you try and jump it after the message you'll need to turn off and restart the engine. you can also push the button on the cluster to reset it too.
if jumping the sensor works then it is likely a bad sensor. if not then suspect a bad wire somewhere.
it is also possible that you cap needs replacing or cleaning
Old Sep 8, 2012 | 09:12 PM
roylb7's Avatar
bad sensor. they dont sell it individual you have to buy the whole over flow unit. 126 bucks.. ill deal with the damn light
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
caissiel
Sep 24, 2015 05:37 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
robbyS
Apr 16, 2015 02:22 PM
97f-250
Nov 23, 2014 08:08 PM
