Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
Removing Water Spots From Glass
Old Mar 4, 2008 | 08:35 PM
JSPulliam21's Avatar
Default Removing Water Spots From Glass
How in the world can I get the water spots off my back and rear side windows. They are dark, so the spots show up really well.
Old Mar 4, 2008 | 09:13 PM
Whit's Avatar
Site Mascot
I found the best to be when it was just washed and then hit it with a shammy
Old Mar 4, 2008 | 09:26 PM
I do that, but no luck.
Old Mar 6, 2008 | 10:35 AM
donnie's Avatar
Try a mesh covered sponge similar to the type used for nonstick cook ware
Iv also had good luck using a very fine steelwool.
Old Mar 6, 2008 | 12:30 PM
DB Admin's Avatar
Banned
https://www.dieselbombers.com/everyt...ht=Water+Spots
Old Mar 6, 2008 | 01:44 PM
I will try the vinegar first. It makes the most sense. Attack the scale on a chemical level!
Old Jan 7, 2009 | 04:22 PM
never2fast's Avatar
there are glass polishes. I haven't used it but I hear good things about diamondite. look them up, they have a lot of products for glass. There is also a cheaper brand called One Grand Products and their cleaner is usually $15
Old Jan 7, 2009 | 06:36 PM
midnite><og's Avatar
rubbing alcohol....
or i heard you can use aluminum polish
Old Jan 7, 2009 | 10:13 PM
01CumminsRam's Avatar
cham-wooow!
Old Jan 7, 2009 | 10:18 PM
Benjamin's Avatar
Bombardier
i've used wax, a clay bar, and CLR on a rag to remove them. if they aren't severe then wax, if wax won't hit it the clay bar and if you throw everything you have under the sink at it then use CLR....
