'96 Suburban 6.5 Turbo Diesel
Old Sep 1, 2012 | 01:33 AM
jrs907's Avatar
Default '96 Suburban 6.5 Turbo Diesel
Hey guys... been lurking a bit and see a lot of good info here. I just picked up a '96 6.5 Suburban 2500 4WD and am pretty happy with it. I did a little research (mostly on here as well as YouTube), put in a new PMD and relocated it with a aluminum heat sink. I changed the oil (nasty) to synthetic, been keeping an eye on fluids, so far so good. Oil pressue seemed to drop a tad with the new oil.. but at hot idle, it's about 25, 40 at cruise speeds. Blowby is minimal, when it's hot, there's a little steam coming from the oil filler, but not much. So is there anything I should be keeping an eye on with these things? I don't want to do any real mods, just want to keep it reliable. I may throw some new DieselRX glow plugs in it before winter hits (alaska). I'm curious what i'm going to get as far as mileage goes, so far i've used 1/4 tank and have gone quite a ways.. It runs and sounds normal (like the other 6.5 I have at work), other than a weird pump sound somewhere from the engine. I guess these have a vacuum pump, maybe it's that, no idea. It's not a tick, knock or metallic sound, but the sound of a pump and seems to have gotten louder over the week. Anyhow i'll continue lurking and look forward to learning more.
Old Sep 1, 2012 | 11:15 AM
ebarresi5894's Avatar
No point in running synthetic if it hasn't been used since day one. I run shell rotella. I get about 18-22 mpg.
Sounds like a vacuum pump, your best bet is to throw it in the trash and get a turbo master or make your own
Old Sep 1, 2012 | 12:13 PM
cviola2005's Avatar
x2. the vacuum pump operates the wastegate. with it leaking, the turbo will not build boost correctly and that would be why it is lurking a bit
Old Sep 1, 2012 | 03:40 PM
jrs907's Avatar
doesn't lurk, or do anything weird, except for the pump noise. cruises quite nicely, but i'll get it checked out.
Old Sep 2, 2012 | 03:20 AM
cviola2005's Avatar
i must have misread it. i thought you meant the engine has been lurking a bit. my bad
Old Sep 2, 2012 | 04:36 PM
Yea the pump is prolly bad same thing happened to me
Brclouse
Nov 18, 2015 08:44 AM
MrMoose
Mar 15, 2015 06:05 PM
tedbIII
Feb 1, 2015 11:09 PM
Snoobly
Dec 11, 2014 11:59 AM
Oct 24, 2014 04:40 AM
