Edge comp install.
Old Aug 31, 2012 | 07:15 PM
GuyWithA24Valve's Avatar
Default Edge comp install.
So I just got done installing an edge comp in my truck. The check engine light won't turn off now. I've double checked all the connections but it still stays on. What do I do?
Old Aug 31, 2012 | 07:26 PM
cummin_un_glued's Avatar
FormerVendor
well were going to need to know what that light is trying to tell you so hook a scanner up to it
Old Aug 31, 2012 | 07:47 PM
P0237 is the code
Old Aug 31, 2012 | 07:52 PM
RAW's Avatar
RAW
Turbocharger boost sensor A circuit low
Something to do with the boost sensor connection.
https://www.dieselbombers.com/codes.php
Old Aug 31, 2012 | 07:59 PM
Well the battery cable touched the terminal accidentally when I was installing the edge. The map sensor was unplugged at that time. Would that have done it? Because I drove the truck to o'reillys to get a scanner and everything worked fine with the edge
Old Aug 31, 2012 | 08:45 PM
FormerVendor
very possible that caused it and its just a stored code not a current code so if you havnt got it to clear yet it should clear on its own after a few start ups
Old Sep 1, 2012 | 12:02 AM
I cleared it with the scanner and it hasn't come back in the 50 miles since then
Old Sep 1, 2012 | 09:03 AM
FormerVendor
cool sounds like your problem is fixed
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
scottxmorris
Feb 6, 2015 05:33 AM
FF131
Jan 21, 2015 11:37 AM
scottxmorris
Dec 31, 2014 03:20 PM
