Need help with front wheel axle seals.
Old Aug 30, 2012 | 02:18 PM
sujumptd's Avatar
Default Need help with front wheel axle seals.
Hey there fellas,
Was replacing my ball joints on my pickup and since I already had it all apart I thought I go ahead and change out all the seals. Ran into a problem and need some help.
On the left front axle shaft right up against the deferential I replace the seal with a new one (photo4) and wanted to replace the ones that go up against the wheel hub and inside the wheel hub, seems like there are two.(photo1&2) What is the right way of changing these out, seems like its impossible to put new seals on because of the way its put together. I could only think of putting them on by sliding them down the outer shaft but there is a plate there(photo3) that stops me from doing this. Basically, could someone show me how to change these outer seals out with out tearing anything up.
Thanks in advance.
Attached Thumbnails Need help with front wheel axle seals.-photo-1.jpg   Need help with front wheel axle seals.-photo-2.jpg   Need help with front wheel axle seals.-photo-3.jpg   Need help with front wheel axle seals.-photo-4.jpg
Old Aug 31, 2012 | 11:28 AM
sujumptd's Avatar
WOW!!!!!
Going on 80-90 views and no one has any idea how how to do this?
Well, "cancel my shout out" because after hours of combing through the internet I've found just exactly how to do it. Hope's this helps others by preventing the torturous internet surfing I spend to find this.
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
Old Aug 31, 2012 | 08:13 PM
nydiver's Avatar
There is about 6 threads on this very site that discuss those exact seals and the methods to extract and replace them. Very sorry that after a few hours you became frustrated that you had not received an answer. Guess we should all just sit here and wait for YOUR questions so that we may provide YOU with immediate technical support.
Old Sep 2, 2012 | 03:03 PM
sujumptd's Avatar
Dang, Guess I'm on the wrong forum......is there not a fully staffed 24/7 tech support staff available eating Cheetos with there eye ***** glued to this forum just waiting for the dumbest questions to come up??
My bad.......didn't mean to get nydiver's panties.....oh, check that....."anyones" panties in a bunch.
Old Mar 7, 2013 | 08:33 PM
edwardmcmorris's Avatar
Lmao thanks for the link anyways bud. Much appriciated
Paul08
Ford Powerstroke 08-10 6.4L
May 9, 2021 11:01 AM
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
