35s on my dually
Old Aug 29, 2012 | 10:41 PM
Bigred7.3's Avatar
Default 35s on my dually
i ran into a grates deal on 6 bfg t/a 35/12.50/17 i need tires extremly bad im not lieing wen i say my tires except one are completly tread less, my question is and please dint flam me to badly because i do kno its not the right way to do this but money is tight for now since i jus bought my new injectors but is it possible to mount the tires in the rear with out the spacer for a week or so, no more then 2 weeks till i can get the money for the spacers they are $260.00. im not gona tow or put any thing in the bed its just gona b daily driving round town minimal highway.
Old Aug 29, 2012 | 11:01 PM
dangerous1965's Avatar
How bad do they touch? What kind of rims are they going on? Stock rims Hell no! It may be a good deal but 12.50 on a daully is crazy wide! Keep searching craigslist.org
Old Aug 30, 2012 | 11:37 AM
Bigred7.3's Avatar
my brother has 37/13.50 toyo open country mts on hit megacad dually mounted on the stock rims with a 2 inch spacer, they mounted fine and the truck rides great.
Old Aug 30, 2012 | 12:26 PM
TheOtherNick's Avatar
Probably could just run one wheel in the rear for a week till you get the spacer.
Old Aug 30, 2012 | 12:35 PM
cummin_un_glued's Avatar
FormerVendor
I ran 35x12.50s on stock wheels with a 2" spacer on my megadually
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Aug 30, 2012 | 09:48 PM
Yes it can be done but should it? The tire will be so sucked in the contact patch will be about 4 inches great for burn outs bad for tire life and stability just my two cents.
Old Aug 30, 2012 | 10:11 PM
FormerVendor
i ran mine at 45psi and they wore flat. ran them for over a year that way with no issues even towing more then the gvwr of the truck.
you do not sound like you know from experiance...sounds like it is mearly your opinion
Old Aug 31, 2012 | 10:45 AM
That's true! Seen it done on other applications where the results were not so good. But hey if it worked then do it. It's just my opinion! Can anyone post a pic of a mounted picture?
Old Aug 31, 2012 | 03:41 PM
FormerVendor
if it stops raining i have a customers truck here right now with the same setup
Old Sep 1, 2012 | 11:31 PM
Keysfisher's Avatar
Default re: Spacers and wide 35's
I got the spacers with 35 nittos and a lift. The truck rides great the biggest thing I notice is mileage dropped about .5-1 gallon per mile but with the wide tires. I tow a backhoe and toyhauler of 18K and 15K no issues. Drive the twisties like a 1000rr no issues. Check my album for pictures
Attached Thumbnails 35s on my dually-dodgerear.jpg   35s on my dually-img_20111025_102955.jpg
