oil pressure sending unit location
Old Aug 29, 2012 | 07:59 PM
shawkir's Avatar
Default oil pressure sending unit location
Cummins marine diesel 6 BTA 5.9 m3 b370 1998. My oil pressure is sometimes irratic depending on the RPM, the sensor/sending unit was not provided by Cummins. where is the sensor/sending unit located?
Old Aug 31, 2012 | 07:29 PM
cummin_un_glued's Avatar
FormerVendor
straight back toward the rear of the engine from the injection pump oil supply line. it will be about mid way between the oil pan rail and the top of the block. takes a oil pressure sensor socket to remove but they can be bought at any parts store for less then $10
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
