Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
Sluggish T444E
Old Aug 27, 2012 | 05:37 PM
Arborman's Avatar
Default Sluggish T444E
Just bought a 2000 IH 4700 with 80k miles. Of course the gauges do their normal job of not working. But I know how to fix that. I have read other threads of similar problems, with no resolve to their problem. Basically this is it- 1st & 2nd gear i get good acceceleration when i shift into 3rd it has NO power. It gets down the highway good, just keep the hills out of the way big or small. There is a pinging sound that sounds similar to a gas motor when lifters float. At 2000rpm's a high pitch sound starts almost like something is vibrating. And lastly it surges or lunges like I am giving it to much throttle, if I let up it goes away.
That being said I do have a very small fuel leak in the valley under the fuel container. The leak is not enough to even make a drip spot under the engine. All filters are new, oil is new-rotella 15-40. Checked boots on turbo-look good but will recheck.
Thanks in advance! Tony
Old Sep 8, 2012 | 04:45 PM
Arborman's Avatar
Apologies for the two posts being posted, not sure how that happened. Today brought about a new challenge. On the way home the TPS lost response, I shut the motor off restarted it and it did fine. Then 5 minutes later-again in the driveway-same thing.
If there happened be a loose connection in the wiring where wood a guy check? I kinda figure it may be the TPS. This morning seemed like it was extra sluggish. Any input would be greatly helpful.
Brian54
Jun 27, 2015 06:21 PM
OBSBEN
Dec 31, 2014 11:35 AM
OMEGA7622
Dec 5, 2014 03:05 PM
ayvahaiden
Nov 3, 2014 07:30 AM
