auto to manuel cummins
Old Aug 25, 2012 | 01:41 PM
codycatract's Avatar
Default auto to manuel cummins
I am doing a 5.9 with 5 speed in my 97 f350 7.3 auto. I bought a cummins 1989 with 80k miles for 1500$. I took off the torque converter cuz im doing a 5 speed, I was wondering are the end of the crank shafts the same auto and Manuel on cummins, I don't see where the pilot bushing could go in the crank?
Old Aug 25, 2012 | 11:17 PM
cumminsf150's Avatar
The crank shaft is the same. Pilot bearing goes in the flywheel. Manuel is my cousins name, your transmission is manual.
Old Aug 26, 2012 | 04:04 PM
Haha blame it on my smart phone, its slower then a streak of sh*t, but for the top end, I took off head and the head gasket was smoked, do I need to be worried about getting the head shaved since ir isn't aluminum
Old Aug 27, 2012 | 12:09 AM
Put a strait edge on it if you have the head off find out now
Old Aug 27, 2012 | 05:24 AM
timdale's Avatar
Put some 60lb valve springs in her too ( at least on the exhaust side) in case you ever put an exhaust brake on. They're cheap, $55
Old Aug 27, 2012 | 02:11 PM
I would probably be better off buying all them since im running 3200 spring don't ya think
An if I have higher rpm and stronger valve springs shoildbi do arp. Push rods?
Last edited by codycatract; Aug 27, 2012 at 02:11 PM. Reason: Automerged Doublepost
Old Aug 30, 2012 | 07:37 AM
prowler48's Avatar
hey im doin a swap just like urs except my 12v is a '94. good luck with urs hope to see some pics!
Old Aug 30, 2012 | 02:12 PM
Im not to go without the computer, don't know how to do pictures and stuff but if I can find someone to post them ill do it, hope to see some off your rig to
Old Aug 30, 2012 | 02:18 PM
prowler48's Avatar
Yeah its been a pretty big job. right now im in the process of putting in the nv4500. so far its been pretty difficult. Might need to do some floor modifications so i can get the dang thing up high enough to get it to the back of the engine without hitting the bottom of the truck. what tranny are u gonna put in?
Old Aug 30, 2012 | 05:12 PM
From e4od to nv4500 I was hoping I didn't have to beat in floor ill probably machine some aluminum body pucks but im only 20 with a budget haha got any pictures you can email me so far
