06 5.9 won't start. starter relay clicks
Old Aug 23, 2012 | 10:44 AM
Megabeast's Avatar
Default 06 5.9 won't start. starter relay clicks
2006 Dodge Ram 3500 5.9 will not start from key- but will start with key turned to on position and B+ jumper to the Yellow/Gray Starter lead wire under the hood. When I try to start with the key I do hear the starter relay clicking but no 12v reaches the starter lead that I am jumping to start thevehicle. Tried another relay and same thing. It is an automatic transmission so I also tried to start in Neutral and wiggle the shifter and still no bueno! I check continuity from the green/yellow wire on the ignition switch to the relay and that is good and same thing for the yellow/gray wire from the relay to the starter. Some where power is not being allowed to pass through the wires. Worked fine o day- Parked it- then wouldn't start- thenn all of a sudden it fired up- ran for two days with starting and stopping it several times and then again- No start and has now been this way for 9 days- I have made a push button switch so I can start thetruck from in the cab with the jumper but I rather correct the situation-
I am jumping to power to the yellow/gray wire that goes directly to the starter solinoid- the clicking soud I hear is from the starter relay which is mounted next to the fuse box and driver side battery. nothing is actually getting to the yellow/gray wire which is why I am needing to jump it to a power source for the truck to start. If it was a bad key then it would shut down- not continue to run. I also tried using the remote start and it also is not working-
Old Aug 23, 2012 | 06:55 PM
DV615's Avatar
Have you checked or cleaned off all (if any) of the corrosion on your battery connections?
Old Aug 23, 2012 | 11:51 PM
Megabeast's Avatar
Yes. Brand new northstar batteries and all new wiring to and from less than a month ago
Old Aug 24, 2012 | 07:57 AM
helton87's Avatar
i dont want to sound like an *** but see if there clean again, because i had new batteries and cables on mine and a few months later i was stranded and took the cables off, cleaned them and she started right up
Old Aug 24, 2012 | 08:36 AM
DV615's Avatar
Yeah, like helton said check them again. When mine had this problem we actually took like a dremmel tool and notched the terminal where the terminal could tighten up more around the battery post(s).
Old Sep 20, 2012 | 11:48 AM
Megabeast's Avatar
Turned out no power from the tipm was reaching terminal 30the on the starter relay. Had to hardwire around the tipm. All is good now. Terminal 30 should always be hot.
Old Mar 23, 2018 | 03:21 PM
cumminsohyeah's Avatar
How did you hardwire around the TIPM??
My '06 has a similar issue and found no power coming back from TIPM in the starter relay base.
I unplugged the solenoid wire by the firewall and installed a push button from battery to starter.
klein444
Jun 20, 2015 11:48 PM
ronstop
Feb 26, 2015 09:48 AM
Kooper
Jan 11, 2015 08:52 PM
texasd
5.9L CR Performance
8
Dec 20, 2014 07:39 PM
mpenny671
Oct 7, 2014 01:18 AM
