1992 Chevy 2500 6.2L Non-Turbo Problems
Old Aug 18, 2012 | 03:11 PM
redneck.4life's Avatar
Default 1992 Chevy 2500 6.2L Non-Turbo Problems
I baught this Ole Chevy a couple weeks ago and i got a problem, the truck seems to struggle going up hills like crazy, ill try to get a running start going up hills at like 60 and by time im at the top ill hit like 35-40 ish if im lucky. and it struggles to get up to 55-65.
I'll go to take off and the truck will take off steatly and then it will jump and get a big burst of energy.
I got a check engine light on, came up as TPS.
I also looked into the truck because it does smoke a lot, and i hurd the inection pump could cause a rough idle, and i do go a slightly rough idle how ever i did post a picutre of the injection pump lines if anyone could tell me if they should be lined up or if what i got is okay.
the transmission doesnt seem to slip, just doesnt shift correctly. if i mash the gas it will down shift and wont go anywhere the engine just acts like its on the rev limiter and slows down
6.2L Non-Turbo
206,xxx Miles
Attached Thumbnails 1992 Chevy 2500 6.2L Non-Turbo Problems-img_20120818_144841-1-.jpg
Old Aug 18, 2012 | 04:40 PM
Mayhem's Avatar
I dont think you have problem with the IP im thinking either a fuel filter or bad LP how does it Idle?
Old Aug 29, 2012 | 05:15 PM
fommy100's Avatar
looks like someone adjusted the timing on the injection pump, to give more power, both lines should be opposite like on my truck, its no speed demon, its a truck to move heavy loads. I would take it in to diesel shop and have them do a tune up on it, they can check the engine speed and timing and do necessary adjustments for you. The trucks use a computer to shift the automatic trans, so if the ecu gets a bad reading from the tps it will upset the gear changes a certain speeds.
Let us know how you get on?
These trucks are built like tanks and will keep on ticking if you look after them.
Old Aug 30, 2012 | 02:54 AM
cviola2005's Avatar
x2
RatsMC
May 4, 2015 05:25 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
greatlakes diesel
Feb 13, 2015 09:55 PM
Dec 15, 2014 01:10 PM
Snoobly
Dec 11, 2014 11:59 AM
