Gearing / speedometer question
Old Aug 18, 2012 | 01:51 PM
Rolson's Avatar
Default Gearing / speedometer question
Ok guys,
I have the Ford N Benz on the road and running well.
The Jeep AX-15 came with an electronic speedometer output, and the Ford uses a mechanical speedometer. I talked to a guy at a speedometer shop and he told me I would need a 35 tooth long shaft gear, and the correct holder, based on a 3.47 rear gear ratio, and 215 70R 14 tires which the tire calculator says are 25.85 inches tall.
He wanted about $260 for the gear, holder, and a new cable.
I found the gear and holder on ebay for $24, and got a speedometer cable from the local junkyard for $15.
When my speedometer on the dash says 60, the gps says only 57. When it reads 70, the gps says only 66 mph. So if I am reading 3 mph too fast at 60, do I need a gear with more teeth, or less teeth to correct it? I suppose I could just go with slightly larger tires, but there are still a lot of miles left on these, so that will be a while.
Thanks for your help.
Rick
Old Aug 19, 2012 | 11:09 AM
Grey Wolf's Avatar
I believe one tooth less will get you were you need to be. My memory is a little fuzzy but I do remember one tooth equaled three mph.
Old Aug 19, 2012 | 07:14 PM
Rolson's Avatar
Grey Wolf,
Thank you for your help.
Rick
Old Aug 20, 2012 | 11:38 AM
Grey Wolf's Avatar
No problem just let us know the outcome. Also before you pick up the gear verify with the speedo shop whether it is in fact one tooth less not more, fuzzy memory you know !GW
Powerstroke36
Sep 21, 2015 08:32 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Feb 18, 2015 01:00 PM
Down South
Jan 11, 2015 01:33 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
