Wanting to drop a Cummins into a '77 Econoline
Old Aug 15, 2012 | 11:41 PM
Dirty Offio's Avatar
Default Wanting to drop a Cummins into a '77 Econoline
Does anyone know if a 1994 12 valve Cummins will fit into the engine bay of a 1977 Ford Econoline van? I have the engine in a wrecked truck, and the van which currently has a 351W gasser in it. I know that the vans came with both a 300 I-6 and a 460 V-8.
I want to be able to tow a camp trailer with the van. (the wife needs a power scooter to get around...so I need the van to haul it.) The van does all right running around empty, but it has almost enough power to pull a greased stick out of wet mud.
If this will not fit, I will probably go with a 6.5 litre GM. I am pretty sure that this will fit, but I would rather have the Cummins in it if there is enough room.
Thanks!
Offio
Old Aug 16, 2012 | 10:33 PM
tiremann9669's Avatar
You might be able to put the Cummins in the back and the scooter under the hood
Old Aug 16, 2012 | 11:09 PM
That's what I'm afraid of!
Old Aug 17, 2012 | 09:22 AM
FTE's Avatar
FTE
There is a guy in Colorado that swapped a 12v in his motorhome that has the econoline chassis, it fit nicely. His build is over on 4btswaps, his user name is Joz I think.
Old Aug 17, 2012 | 02:32 PM
FTE,
Found one, the guy with the Flair motorhome? Was talking about swapping in both a 4bt and a 6bt?
I wish I knew if the engine bay dimersions are the same/similar from '77 and '90.
Thanks for pointing me at that build!
JoeyMiR
9
Feb 3, 2018 10:05 PM
Sbboozer
Nov 16, 2014 05:52 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
