Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
06 Duramax Shaking at an Idle
Old Aug 13, 2012 | 08:08 PM
Dustyt07's Avatar
Default 06 Duramax Shaking at an Idle
i have an 06 GMC 3500 Cab and chassis with a 6.6L Duramax.
It is shaking really bad at an idle and smooths out a little at higher RPMs, When first looking at the motor i was thinking maybe injectors. After doing a cut out test it seems like all injectors are firing properly.
I did find the balancer bolt was backed all the way out.
A buddy seems to think this is a balance issue and not a fuel problem
I need HELP!!! This is an over the road truck!!!
PS after tearing down to the balancer it appears that the balancer is in good shape, is it possible that it could have spun on the rubber or could the key-way have sheared?
Thanks in advance!!
Tyler
Old Aug 13, 2012 | 08:21 PM
2500HeavyDuty's Avatar
Thanks in advance!!
Tyler
the keyway could of sheared off. if that's the case you can get a kit to key the crankshaft and put a balancer back on it.
Old Aug 13, 2012 | 09:16 PM
Dustyt07's Avatar
what is the best way to remove the balancer since there are no bolt holes to use a puller?
Old Aug 13, 2012 | 09:41 PM
It should slide right off, but it looks like its really messed up. Pulling the Rad out and probably using some pry bars to walk it out. Its a tight fit to begin with so be careful.
Sent from my Xoom using Tapatalk 2
Old Aug 15, 2012 | 04:39 PM
Dustyt07's Avatar
any other ideas on how to remove the balancer???
It will not budge, i have tried prying all around the best i can and prying and tapping at the same time and no luck.
Old Aug 15, 2012 | 06:08 PM
youre gonna have to drill holes in it and use a puller to remove it then. you can find a used balancer pretty easuly guys are ditching the stock ones for after market.
Old Aug 19, 2012 | 10:15 PM
Dustyt07's Avatar
drilled the holes and tapped them out to use a puller. Worked like a charm! Pin on crank had sheared off and spun the balancer.
Now on to the subject of repairing the pin and crank without pulling the motor?
Any ideas and help is greatly appreciated!!
Old Aug 19, 2012 | 10:31 PM
See if you can drive the pin out with a punch, sometimes you can get lucky. I've heard people using a drill bit for a new pin but I sure as hell wouldn't do that .
I think I know of a guy who is selling an lbs balance actually.
Empire diesel performance sells a kit to pin the crank shaft. Check out their site, I know there are other companies who offer something, maybe fleece performance
Old Aug 19, 2012 | 10:43 PM
http://www.empiredieselperformance.c...art&Itemid=109
jt19
Jul 13, 2015 03:06 PM
Tanker6.0
Apr 9, 2015 10:43 AM
duramaxtuner
Dec 10, 2014 01:24 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
