A/C bypass
Old Aug 12, 2012 | 07:15 PM
kawie400's Avatar
Default A/C bypass
Can anyone tell me how I can get my A/C compresser to come on bypassing it??? Any Info would be get.
Thanks
Old Aug 12, 2012 | 07:20 PM
fordornothing's Avatar
bypass as in get rid of it? or what?
Old Aug 12, 2012 | 08:12 PM
kawie400's Avatar
No I want the compresser to always be on. I talked to Joe some time ago and he bypassed it so it would lways come on.
Old Aug 13, 2012 | 08:18 AM
CMCA Swartzkrautheim's Avatar
y would you do that? in my chevy i had it on a toggle switch so that i could turn on ac on my feet or what ever position i choose, all you have to do though is on the side of the pump there is a two prong plug just fig out if you need a live 12 volts to top or bottom and youll be good just tap appropriate wire...
Old Aug 13, 2012 | 10:52 AM
jamsmith's Avatar
Why do you want to do this????
Old Aug 13, 2012 | 11:04 AM
CSIPSD's Avatar
I have a bad HP switch, so I just have a jumper wire from one side to the other on the high side switch.
My AC pump is on, per the factory programing, in every setting but vent.
Thats how they are from the factory.
What are you trying to do?
Old Aug 13, 2012 | 09:09 PM
kawie400's Avatar
I've got a/c in the system but that compresser won't stay on. I remember seeing yours but don't remember what it looks like. That's all
Old Aug 13, 2012 | 09:51 PM
CSIPSD's Avatar
Get some pressure gauges, more then likely you have a pressure issue. Could also be the clutch is wore out, which will cause it to cycle...
But you can pick up a set of pressure gauges at Orielys...
Old Aug 13, 2012 | 11:40 PM
A/Ox4's Avatar
I'll bet this will fix it.
SpringerPop's Compressor Clutch Air Gap
Old Aug 16, 2012 | 04:23 PM
kawie400's Avatar
This seems easy, but can anyone do this. That If I took out the shims all togethers. I've seen video of guys taking them out and not putting them back on. Is this bad???
HunterMike
Aug 14, 2015 08:47 PM
Maclain Marsh
Jul 13, 2015 06:23 PM
helton87
For Sale
Jun 3, 2015 02:36 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
Detroitdiesel97
Mar 10, 2015 06:02 PM
