.tranny fluid change
Old Aug 12, 2012 | 06:57 PM
Bigred7.3's Avatar
Default .tranny fluid change
my truck has 188,000 miles on her, ive started noticinc im geting a little hesatation every once in a while when putting the trans in drive after sitting for a while but she runs strong and pulls fine, and sometimes when im crusing and step on it shel slip then go into gear, i know im prolly dues for a rebuild soon but i need to run this rranny for a lil while longer, im thinking a fluid and filter change would do it some good but over the years ive always heard conflicting arguments that its bad to change thr fluid cuz itll make it worse, any one have any real facts, if any one here has changed the fluid in there trans with out problems let me kno and whats the best fluid to use
Old Aug 12, 2012 | 07:29 PM
RanchhandTCR's Avatar
No change it and adjust the bands and I bet most of your problems will go away.. Reason for the failure of the auto trannies are because of lack of maintaince. at least for the 2nd gens.
Old Aug 12, 2012 | 09:10 PM
TheOtherNick's Avatar
Yup, service the trans and adjust bands.
Old Aug 13, 2012 | 01:45 AM
Bigred7.3's Avatar
ok thays good to kno. how do i adjust the bands
Old Aug 13, 2012 | 06:46 AM
rufushusky's Avatar
See attached. Personally when I had a dodge I ran whatever ATF+4 was cheapest at the time.
Old Aug 13, 2012 | 11:20 PM
Bigred7.3's Avatar
i read tje instrucion but i dont understand the why its saying to tighten down the adjusting screw tk spec then turning it bac out b4torqing the nut down...
Old Aug 14, 2012 | 12:51 PM
You toque the set screw then back it off the set amount of times to set the correct p reload.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PA 24valve
Aug 31, 2015 07:39 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
MBFD 592
Jan 1, 2015 11:37 PM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
