Can i use regular diesel on 2010 dodge ram cummins?
Old Aug 12, 2012 | 02:53 AM
Abdul's Avatar
Default Can i use regular diesel on 2010 dodge ram cummins?
Hello,
Can some one help me with this?
I'm from kuwait and i'm planning to order 2010 dodge ram 2500 Cummins from the united states. And i'm facing one problem which is we don't have Ultra low sulfur diesel here in kuwait.
So, is it possible to use regular diesel or low sulfur diesel Instead of ultra low sulfur diesel on this truck?
If no, what is your recomendations for me?
Thanks.
Old Aug 12, 2012 | 07:38 PM
daveO's Avatar
The main problem with running LSD in a truck requiring ULSD is the emissions equipment. If you get the truck you will likely be fine with deleting the DPF and the EGR. I'm not an expert on these newer trucks, but I'm sure someone with more knowledge will chime in.
Old Aug 14, 2012 | 07:01 AM
89silverbullet's Avatar
dont the 6.7's have variable geometry turbos? I know that kind of turbo hates everything but ultra low sulfur diesel.
Old Aug 14, 2012 | 06:19 PM
baddodges's Avatar
Regular diesel will create to much soot and plug your dpf and cat and egr components. I would do the delete on the cat dpf and egr then you shouldn't have a problem.
Your profile doesn't show much info are you in the military over there?
Old Aug 30, 2012 | 11:20 AM
TwinAuroraCummins's Avatar
Yep, egr and dpf delete and go with a holset hx 35 turbo. The turbos in the 6.7 hate reg diesel.
Old Aug 30, 2012 | 12:02 PM
H.R.D's Avatar
HX35
Go with a 62 mm turbo not an HX35.
Old Aug 30, 2012 | 03:46 PM
It's a bigger turbo than whats already in it. hx35 or hx40 I only said that, unless you can afford a Aurora 3000 or a 5000
Old Aug 30, 2012 | 03:53 PM
H.R.D's Avatar
An HX35 is a 54/58/12 why would you want to put a smaller turbo on then factory? An HX40 is around a 60/65/16(different sizes too). An HX40 is a better option than an HX35 for sure.
Aug 13, 2015 11:50 AM
raude1
Apr 13, 2015 03:38 PM
Nov 3, 2014 08:10 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
