6.5 turbo diesel boost gauge?
Old Aug 11, 2012 | 10:58 AM
duckslayer31's Avatar
Default 6.5 turbo diesel boost gauge?
im looking to install a boost gauge in my 99 6.5 turbo diesel! i have a glow shift gauge allready i just dont know how to install it! if you could help me out that would be awesome
Old Aug 11, 2012 | 11:46 AM
ebarresi5894's Avatar
Yup real easy. Take off you upper intake plenum, drill a hole in it anywhere you feel comfortable on it that will fit the thread of the probe of the gauge usually a 1/8 pipe thread and you need a letter Q drill bit , tap it and then follow the hose to the gauge in the cab and your good to go.
That easy
Old Aug 12, 2012 | 08:56 PM
ive also been told that i can tap into the waste gate hose? is this true? how about the electronic part of it! do i need and inline fuse? would it be easer to hook it to a toggle switch or to the fuse box?
Old Aug 13, 2012 | 04:49 AM
No power needed because its mechanical only power is for the light. And I would just put it on intake manifold.
Old Aug 13, 2012 | 05:56 PM
Ghost0038's Avatar
I just did mine on a 95 6.5, took maybe an hour. I just installed it right in the top center of the upper plenum. I also picked up a new gasket for about $6 bucks at my local Orileys. I tapped into the green wire coming from the headlight switch which is for the dimmer circuit.
Old Aug 13, 2012 | 10:28 PM
what about the orange and yellow wires?
Old Aug 14, 2012 | 02:47 AM
cviola2005's Avatar
can you show a picture of this gauge? and the wires coming out of it?
Old Aug 14, 2012 | 11:02 AM
Old Aug 14, 2012 | 02:11 PM
cviola2005's Avatar
not sure which gauge you have, but below is a link to the installation instructions at glowshift. hope this helps
GlowShift Technical Support - Installing Glowshift Gauges
Brclouse
Nov 18, 2015 08:44 AM
timmyd
Jun 8, 2015 11:35 PM
MrMoose
Mar 15, 2015 06:05 PM
Snoobly
Dec 11, 2014 11:59 AM
Oct 24, 2014 04:40 AM
