Transfer case shifts itself?
Old Aug 11, 2012 | 12:04 AM
5280jeff's Avatar
Default Transfer case shifts itself?
Hi guys, I have a 2007 Mega Cab with a 6.7l turbo diesel and auto trans. Today my transfer case started shifting in and out of 4x4 by itself. It has done it while driving and also while in park with the engine running. I can hear the transfer case shifting under the truck while I'm parked. Any help would be appreciated.
Old Aug 14, 2012 | 07:45 AM
Grrrr's Avatar
check all the electrical wires and connections for corrosion/water....
Old Oct 2, 2012 | 03:31 PM
FreeseDiesel's Avatar
if im not mistaken, i belive there is a flash for this problem at your local dealer.
gotta love electrical everything huh?
Old Jan 7, 2017 | 05:19 PM
JForbes's Avatar
I am also having this problem. I first noticed it when turning in a parking lot and all of a sudden I'm in full 4WD Lock. I also have noticed the shift motor operating when the key wasn't even in the ignition. It started after I had the transmission replaced and the shop had to repair the transmission wiring harness. A short was causing it to go into limp mode.
Now the T-case is stuck in neutral and I'm broke down!!!
dezeldoc
Wanted To Buy (WTB) - Used
Jan 27, 2016 05:08 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
