6.2 problems
Old Aug 5, 2012 | 06:09 PM
metalhead152's Avatar
Default 6.2 problems
Hi guys, I have a 1500 GMC 6.2 with running issues. It wont stay running on a colder morning (around 15 Celsius) I cant hear the fuel pump run every time I crank, sometimes it will sometime it wont. I wired in a light parallel to the fuel pump to see if it was getting power/ground and so far it has both (the light stays lit) sometimes. >_>
How does the fuel pump get its power? I understand the oil pressure switch sends power to the relay then the relay sends power to the pump? Is that correct?
Thanks for the help guys :P
Old Aug 5, 2012 | 06:30 PM
Mayhem's Avatar
Yes the oil sending unit controls the LP if you run a wire from the positive terminal on you're battery to the G terminal on the OBD1 port under you're dash after opening the T valve and fuel comes out of it you should probally change the OPS
Old Aug 5, 2012 | 07:00 PM
So sending power down the G terminal Will send it through the OPS, and then to the Relay (causing it to *click*) and ultimately the LP? Sorry I don't have a schematic. Thanks for the quick response!
Old Aug 5, 2012 | 08:09 PM
Mayhem's Avatar
sorry I meant to put this on here earlier
Old Aug 6, 2012 | 10:08 AM
I should change the ops if fuel comes out? Putting power to terminal G in NOT suppose to make the LP run?
Old Aug 6, 2012 | 10:27 AM
Mayhem's Avatar
Power to terminal G will make LP run if it is good this is helpful when bleeding the fuel system as well
jedder21
Mar 7, 2015 09:47 PM
joealto91
Dec 8, 2014 06:54 PM
Caveman94
Dec 8, 2014 12:21 PM
DanielC559
Dec 8, 2014 06:20 AM
jdcarter
Nov 29, 2014 11:31 AM
