97 PSD fuel in oil need help.
Old Aug 4, 2012 | 07:19 PM
fudgie70's Avatar
Sad 97 PSD fuel in oil need help.
Getting excessive fuel in my engine oil. Truck still runs good no white smoke no strange noise. Was told by a ford tech sounds like the lift pump went bad. Has anyone else had this issue with the lift pump. Thanks for any help am new here too. This happened fast was fine one week next week checked the oil and found the issue. Maybe 200 miles thanks again.
Old Aug 6, 2012 | 01:35 PM
CSIPSD's Avatar
You have fuel in your crank case oil...
About the only way that can happen is with the fuel pump, if its leaking down into the case thru the pump rod.
No other way I can think of off the top of my head.
Old Aug 7, 2012 | 02:00 AM
fudgie70's Avatar
Thanks for responding was getting worrried nobody ever had this issue. Guess I will try replacing the pump and go from there. The truck only has 120,000 on it so was hoping it wasn't time for injectors yet. Thanks again
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
bigredcummins
Jan 4, 2015 04:37 PM
