runs bad at half throttle
Old Aug 3, 2012 | 08:53 AM
tillett70's Avatar
Default runs bad at half throttle
When you drive it easy the truck runs fine but about half throttle it spits and sputters and smokes then if you put it to the floor it smooths out. just installed new pmd and pickup pump and air cleaner and checked numerous other things Hope someone can help thanks
Old Aug 3, 2012 | 09:28 AM
Mayhem's Avatar
What codes do you have?
Old Aug 3, 2012 | 04:42 PM
tillett70's Avatar
No codes
Old Aug 3, 2012 | 09:09 PM
Mayhem's Avatar
I it hard to start sometimes or all the time???
Old Aug 4, 2012 | 08:41 AM
tillett70's Avatar
Has no problems starting
Old Aug 4, 2012 | 05:55 PM
Mayhem's Avatar
It may be the PPS?????????????but i would think it would throw at least the service throttle soon light
Old Aug 6, 2012 | 08:42 AM
tillett70's Avatar
just started having starting problems yesterday it started and then died and it took about thirty minutes to get it started again and someone told me it might be my IP going bad
Old Aug 6, 2012 | 09:52 AM
Mayhem's Avatar
IP's usually when they start going bad are hard to start when they are hot this is easily diagnosed by pouring cool water on the IP then it will start right up,Kinda sounds like a CPS mine went bad and showed no codes if you replace you're CPS buy a AC/DELCO CPS dont use a BWD as they are junk and will act the same as a bad CPS
bdbfam
Aug 31, 2015 09:06 PM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
Freezzman
Jul 6, 2015 03:01 PM
Jake202
Jun 21, 2015 09:42 PM
1stgenswap
Nov 3, 2014 09:45 PM
