Longer to start then black smoke
Old Aug 2, 2012 | 07:43 PM
samjesse's Avatar
Default Longer to start then black smoke
Hi
250 Kilometers on the odometer. i.e. 125K Miles.
It has been running fine (It used to start the same second I crank it.) till one cold early morning, Cranked till killed the battery, Jump start "cranking" finally started with a good size buff of black smoke. Took it to work, Started fine every time.
Again same thing happened next day, Battery tested OK.
Left it for few hours, the longer I leave it the longer it takes cranking before it starts and blows the black smoke.
When I turn the key on, the dashboard light "Wait To Start" comes on/off "cycles and I could hear clicking" for few times before it becomes ON solid, then I start it.
What would be the most efficient course of action?
many thx
thx
Sam
Old Aug 2, 2012 | 08:36 PM
Mayhem's Avatar
Any codes??????
Old Aug 2, 2012 | 09:04 PM
samjesse's Avatar
Originally Posted by Mayhem
Any codes??????
Non.
Old Aug 2, 2012 | 09:33 PM
Mayhem's Avatar
Glow plugs maybe,take them out and test them
Old Aug 2, 2012 | 10:12 PM
samjesse's Avatar
1 ohm?
do I need to remove them? i.e. disconnect and ohm test feed to ground wouldn't do?
Old Aug 3, 2012 | 05:02 AM
Mayhem's Avatar
I had a few G.P.s pass the ohm test and turns out they would'nt light up like they were supposed to ????
Poppie5x
Mar 22, 2016 12:10 PM
cooler364
Mar 26, 2015 10:58 PM
sootman
Jan 22, 2015 05:12 PM
gator515
Jan 14, 2015 01:56 PM
Domrig13
Dec 12, 2014 01:24 PM
