Stupid question
Old Aug 1, 2012 | 11:38 PM
jamesrett's Avatar
Default Stupid question
Soooo, i was wondering. If I have a 3 inch down pipe, does it really matter what size the rest of my exhaust is as long as it 3 inch also. A 5 inch exhaust wont make a difference if my choke point is 3 inch. The reason I ask is that I am making two trucks out of one. The truck thst gonna be driven has a rag-tag 4 inch straight pipe exhaust but the donor truck has a new 3 inch exhaust with muffler. I just have the down pipe and a edge programmer that I leave on the tow setting. Any thoughts?
Old Aug 2, 2012 | 08:12 AM
joebob3093's Avatar
Moderator
You can run any size exhaust you want
Old Aug 2, 2012 | 09:53 AM
RAW's Avatar
RAW
Personally, I'd step it up to 4" after the down pipe. 3" may have a slight restriction, and will be louder then 4".
Old Aug 2, 2012 | 11:35 AM
CSIPSD's Avatar
I would go from the 3" to a 4". The 4" will open things up offering a bit less resistance.
Old Aug 4, 2012 | 07:19 PM
twinboys's Avatar
Resistance is addative. That is the resistance from each component (or section) is added together to give total resistance. The resistance of each section is proportional to it's length and (disregarding boundry conditions, etc.) inversely proportional to the square of the diameter. so... if the resistance of the 3" is 1/9 units (.111) then the resistance of the 4" is 1/16 units (.0625).
example: if the three inch down-pipe is 3' long and the rest is 9' long,
A 3" exhaust would have .111 X 12' which = 1.332 units of resistance.
A 4" exhaust w/3" d.p. would have (.111 X 3') + (.0625 X 9') = .8955 units.
(Very roughly speaking)
Old Aug 4, 2012 | 07:31 PM
jamesrett's Avatar
Ummmm. I thought this wasn't rocket science but maybe I was wrong. Lol. Makes sense, just hate to ditch a good exhaust but also don't want to go backwards in performance.
Old Aug 5, 2012 | 12:06 PM
Haveastroke's Avatar
spray paint a strip down the pipe. start and run the truck. where ever the paint stops burning of you can go as big as you want.
Old Aug 8, 2012 | 07:51 AM
twinboys's Avatar
I was told that the turbo (on a diesel) provides enough back pressure and therefore you can immediately go as big as you want.
Old Aug 8, 2012 | 10:40 AM
CSIPSD's Avatar
You were told correct.
The turbo is all the back pressure you need. Anything beyond that is a restriction.
However, nothing larger then 4" will show any improvements in performance... The 5" systems you see out there are for looks and sound.
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
